Resets the QoS profile assigned to the EXP value back to the default QoS profile.
| value | Specifies the EXP value whose QoS profile is reset. |
The QoS profile matches the EXP value + 1.
This command resets the QoS profile assigned to the EXP value (defined by the value keyword and argument) back to the default QoS profile. If the all option is specified, all EXP values are reset back to their default QoS profiles. By default, the QoS profile matches the EXP value + 1. That is, EXP value of 0 is mapped to QoS profile qp1, EXP value of 1 is mapped to QoS profile qp2, etc. This configuration has switch-wide significance.
Use the following command to restore the QoS profile of EXP value 5 to its default setting:
unconfigure mpls exp examination value 5
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
